“Superman” Speakers
Discussion in 'General Audio Discussion' started by DaBigTookie, Dec 8, 2018.
  1. DaBigTookie
    DaBigTookie New Member
    28
    A008A1A9-2005-432E-AF78-8FF1A037E35C.jpeg BF18D05F-80B7-4CDA-9487-B841B846B62C.jpeg 8C9B2B96-1B0F-40F6-B176-862EACE8823F.jpeg 33625F6C-DF2B-4180-9BFA-3BE36206D95E.jpeg 90B850DD-AA8B-4713-A662-6FA4B585597E.jpeg 385ED2A3-6CDA-4D5B-B79F-2B74F1BC8BC9.jpeg 9D3675FF-95FD-426B-8E48-5FD42B9B1B97.jpeg 95CAD0DB-4400-424E-B254-E2E53035E5A3.jpeg D3DE4076-1B8D-4E64-B8AC-E370EE2B152A.jpeg 5B82A7FA-2FD3-4723-BFD4-E7E15D9EFD8B.jpeg A008A1A9-2005-432E-AF78-8FF1A037E35C.jpeg BF18D05F-80B7-4CDA-9487-B841B846B62C.jpeg Hey guys, just wanted to see if
    anyone knows what these speakers are?
    I referenced Superman because of the obvious top of cabinet picture design.
    Looks to be from the late 70’s just because of the look.
    Bi-directional design:
    Each top half houses (2) 8” drivers, (2) 3” mids, (2) 1” tweeters
    38” H x 16 1/2” W x 10”D
    45 LBS each
    ev13wt, John Daly, Ds2000 and 2 others like this.
  2. just dave
    just dave vintage rules!
    7,750
    Oak Forest ILL.
    Looks like a homebrew to me.
  3. sqlsavior
    6,290
    Española NM
    Those are so cool. It looks like someone took inspiration from the DCM Timewindows. They look too finely finished to be prototypes. I love how the chamfered edge shows off the oak grain. And the handles, and access ports! So sensible! And the transformer/autoformer in the crossover, probably for level-matching the drivers. Someone was a DESIGNER!
    How do they sound?
  4. hugo454
    hugo454 Gold Member Subscriber
    1,633
    south florida
    Allison resemblance
  5. DaBigTookie
    28
    They actually sound very balanced and open.
    Running them on Musical Fidelity A300 integrated right now, will try them on a Jolida Integrated tube in a week.
  6. DaBigTookie
    28
    I’m not sure if they are homemade, just because everything looks too precise?
  7. TomBig58
    TomBig58 AK Subscriber Subscriber
    944
    Chicago
    They look very homebrew to me. (Or built by DCM lol) Plywood front panels vs MDF the woofer cutouts look jigsawed. The backing plates for the woofer screws. Crossover parts mounted to the underside of the oak top. Mid driver cutout obviously used a simple smaller drilled hole before driver big circle cut to accommodate the wire terminals. Maybe a side project from someone in a small speaker shop? Very cool. No port. Was there any fill inside the cabs? With no port/transmission baffles are they a little bass shy? I think they are pretty attractive. Print a large stylized Superman "S" and tape it to the top?
  8. DaBigTookie
    28
    Some speaker fill inside the cabinet, bass is somewhat what you’d think it be with no port, has a classic sound and fills the room easily.
  9. the skipper
    the skipper Amateur Curmudgeon Subscriber
    3,119
    Aggieland
    If they float your boat, then add a quality sub to extend the low end and you should be fine.
  10. DaBigTookie
    28
    Still trying to put together what these might be, mids are coming up as a possible drivers from Marantz?
  11. kfalls
    kfalls Super Member
    1,143
    Dennison, Illinois
    They look like Soundwave Soliquitys to me.
  12. manu et deo
    manu et deo I'm loving it! Subscriber
    970
    SW Riverside County, CA
    I'm a member of a Facebook group where the guys make stuff that blow commercial offerings away.
  13. imral3
    imral3 Super Member
    3,636
    Blackwood, New Jersey
    Look like well built homebrew to me.
