1 meg Potentiometer Question?
Discussion in 'Tube Audio' started by tube-a-lou, Aug 2, 2018.
  1. tube-a-lou
    tube-a-lou Super Member
    4,431
    Hi all,
    I have a old Fender tube amp and it uses a 1 meg pot which is giving me a noise
    problem, so it measures about 850K on my meter if I put in a new old stock one that
    measures a true 1 meg or so would there be a sound difference or no.
    Thanks
  2. mroboto
    mroboto Super Member
    1,573
    It will only be slower to level up
    Edit:
    At 1 position, the sound level will be approximately like it was at 0.85 before.
    At 10 , 8.5...
  3. knockbill
    knockbill Addicted Member
    8,113
    SE PA
    Also, make sure it is the same taper as the one you replace,,, with a linear taper, if you turn the pot halfway, the resistance measured on each side will be equal...
  4. maxhifi
    maxhifi AK Subscriber Subscriber
    3,403
    Edmonton Alberta Canada
    Have you tried cleaning it with contact cleaner? The value being off isn't a big deal, but if it's noisy and contact cleaner is ineffective a new one could fix that. What fender and what pot?
  5. triode17
    triode17 Super Member
    1,389
    The pot. you get may also be about 850k. I find that they tend to run low in resistance in general, unless you buy an esoteric, expensive one.
    Go ahead and install it, should be fine. When i rebuilt my '66 Fender Vibro-Champ, I left the original pots in there.
  6. steerpike2
    steerpike2 Super Member
    3,369
    Transvaal, South Africa
    What does "level up" mean?
  7. tube-a-lou
    4,431
    It's a Fender Deluxe 5B3 from 1953, I'm replacing it with a original CTS 1 meg audio pot I picked
    them up and measured at 1 meg.
  8. mroboto
    1,573
    Crank up in my approximative english.
  9. tube-a-lou
    4,431
    This is interesting I decided to change out the 60 year old pot that was in the
    amp with a newer nos CTS pot, the old one measured 835 ohm, the CTS
    is 1.045 meg. It does sound a bit different more mid's I say, I'll try it for awhile
    to see how it sounds.
