1217-1290/LE 175 help needed
Discussion in 'The Lansing Legacy' started by Mcenroe7, Oct 5, 2018.
  1. Mcenroe7
    Mcenroe7 Active Member
    419
    Hi all..hopefully someone knowledgeable on this can help me..I’m attempting to go a little out of my “refoam only” technical skills on speakers. Recently I obtained a pair of C38..they sound great EXCEPT one of the 1217-1290 drivers is very noticeably lower in sound. I switched the N1200 crossovers to eliminate them as the “culprit”, so the issue is definitely in the driver itself. Would this be a diaphragm issue, and if so, would anyone be able to tell me which one to purchase? And also, is it a somewhat easy job to replace for a “willing to try” novice? :)
    I will include pics of the meter reading I got..and also, this driver is the 8 ohm version.
    Thanks in advance!
  2. robertgalka
    robertgalka New Member
    44
    Winnipeg Manitoba
    32 ohms is really high. Open it up and check for corrosion or a loose connector. Radian makes a good aftermarket diaphragm for a LE175.
  3. EarlK
    EarlK Well-Known Member
    590
    Richmond Hill, Ont.
    +1
    The problem might simply be corrosion ( or a loose wire ) on the inner terminal connection .
    Opening up the driver removes the wax seals ( unfortunately reducing the resale value of the driver ).
