I've been building Mr. Gillespie's little Magnavox 8600 revision amp numerous times......and consider it both a GREAT amp when done, as well as just a fun project! So nice to see something like this come around and be such a great 'learning tool' not to mention providing such satisfaction when completed. Again, thanks to Dave for sharing his work on this revision.
So, now it comes to some of the things I've done to actually 'modify' Mr. G's modifications....which up to this point has been pretty minimal. I've worked pretty much exclusively with 5K PI OTs with 8 ohm secondaries, or combination 4/8 secondaries....but I've maintained the circuit as Dave developed it with using the feedback off an 8 ohm output. But, I've been asked to now do two things in building one of these amps: 1) change from the 8 ohm secondary to a 16 ohm secondary. And 2) substitute a 6SN7 for the 12AX7. While the feedback issue will be a necessary bridge to cross, the main subject of this post is to see what kind of thoughts, suggestions, comments might come from attempting to make this change in the circuit? For the record, I have checked the filament current draw issue out, and that doesn't seem to be a problem as I'm using all new parts for this build, including a new power transformer, and it's well capable of delivering all the needed 6 volts power to the filaments of the 6SN7 as well as the EL84s. I could actually substitute some 6V6 tubes for these as well, and make it an 'all octal' amp......and I might do next. But, for now, I have to cross the bridge of changing the 12AX7 to a 6SN7, and I guess I just wonder what kind of 'trouble' I could be making for myself here? As noted in the circuit, the plate voltage as designed is 137 VDC.....which is well within the limits of the 6SN7. But, is it enough? Should that get 'increased' some? If so, it seems the 470K resistor ahead of the plate could be 'adjusted' to accommodate that. Likewsie if the 6SN7 would actually perform better at an even lower voltage, again, the 470K resistor could be increased as well.
Then there's the issue of the cathode resistor; should it remain at the designed 820 ohms, or while that may be great for the 6BQ5, the 6SN7 would perform better with a different value in this position? I'm hoping that someone with some familiarity with this tube will have some advice for me. But, I also am wondering if I've forgotten to take anything else into consideration? Like that say, some times it's what you 'don't' ask that causes you the problems.
So, that's it! If anyone has any comments, please post 'em!! And if you want to make any suggestions regarding any adjustments to the feedback values (currently 10K and 300pf)....that would be great as well.
Thanks All!!
Tom D.
Thanks All!!
Tom D.
