1550 pops on shut off
Discussion in 'Marantz Audio' started by Electone, Mar 18, 2017.
  1. Electone
    Electone Well-Known Member
    731
    London, Ontario, Canada
    A friend of mine brought over his 1550 to check over. It sends a nasty pop through the speakers when you shut it off with the speaker a or b button on. If you turn off the speakers and shut it off, no pop. I cleaned the main relay and set the offset to the proper 0V (it was way off at -160mV per channel). One thing I can't adjust is the idling current. The pots aren't doing anything and showing 0V all the time. They are supposed to be at 24mV. Is there anything else I should be checking?
    Thanks
  2. don philipe
    don philipe AK Subscriber Subscriber
    1,111
    West plains mo
    I have two 2275's that pop when powered down,it's not a loud pop,I just hit the speaker button before powering down and learned to live with it.If you find a solution let me know.
  3. willyrover
    willyrover Super Member
    3,033
    Hamilton
    For bias adjust, are you using the correct test points?
    For the pop on turn off, it sounds like the relay isn't releasing fast enough. The relay is supposed to open and prevent this pop from getting to the speaker. Once you have confirmed the relay itself is good isn't sticking mechanically, I would start by checking diodes, resistors, and capacitor values in this circuit.
    KutzlerTrans likes this.
  4. Electone
    731
    Yes, definitely have the correct posts. J708+ J709- for R731. J710+ J711- for R732. I only get 0V and the pots do nothing. Going to check again. Had no problem setting the offset. I will measure some voltages on that board. Thank-you.
