160watts 8 ohms /200 , 4 ohms watts vs 100 watts 8 ohms / 200 watts , 4 ohms
Discussion in 'Solid State' started by qguy, Jul 13, 2018.
  1. qguy
    qguy Super Member
    1,366
    Manila, Philippines
    Which would be better to drive a loudspeaker with a rating of 87 db with 3 ohms minimum (Alon Model IV)
    Pioneer SX-1250 receiver - 8 ohms, 160 watts / 4 ohms, 200 watts
    Aragon 2004 - 8 ohms ,100 watts / 4 ohms, 200 watts
  2. sfox52
    sfox52 AK Subscriber Subscriber
    3,919
    Maryland
    I would bet the Aragon amp will be happier with your Alons.
    kjello likes this.
  3. savatage1973
    6,841
    NW Pennsylvania snow belt
    The Aragon will stomp all over that Pioneer--especially under a difficult load. I have owned two Aragon 2004's and still own two Aragon 4004's. I used both to drive Infinity Kappa 9's that drop below 1 ohm and they remained stable.
    kjello likes this.
  4. birchoak
    birchoak Hi-Fi Nut Subscriber
    792
    Amesbury, MA
    I thought the SX-1250 was unstompable! Not designed for lower than 4 ohm loads? Wow, this is like hearing King Kong cannot bench press 500 lbs. :(
    (Note: I do not own an SX-1250 but have come to respect it via the grapevine).
  5. savatage1973
    6,841
    The SX-1250 is certainly no slouch, but wattage and current capabilities are two different animals (I know--Ohm's law and all the physics), but I paired the K9's with two Carver M 4.0t amps--375 wpc/8 ohm (biamped) and they went into protection faster than you could blink. They run fine on Aragons, and in their current set-up, being driven by four Krell KMA 160's--a mere 160w each @ 8 ohms, but factory rated at 1280w each @ 1 ohm, and (as per the factory manual), can be "tweaked" to operate below 1 ohm. Granted, they weigh ~100lbs each, draw 8A current (each) at idle, have capacitors the size of beer cans, and you can cook eggs on them after an hour of idle operation, but it is what it is.
    Roadrash likes this.
  6. qguy
    qguy Super Member
    1,366
    Manila, Philippines
    So even if their both are delivering 200 watts into 4 ohms, the Aragons will provide more current ?
  7. spark1
    spark1 Super Member
    1,924
    The Great Midwest
    ^ This.
  8. Silentnet
    1,029
    Charleston, SC
    I don't think the 2004 is enough amp either... Why side-step?
  9. spark1
    spark1 Super Member
    1,924
    The Great Midwest
    Why is the 2004 a poor choice?
  10. savatage1973
    6,841
    The move is certainly not a "side-step". Just pop the hood and look. The simple fact that the manufacturer states a minimal increase in power rating @4 ohms vs the 8 ohm power rating says a lot. An amp that truly "doubles down" as impedance is halved has "got the goods" to back it up.
    It is not. It is a "baby Krell", basically designed and parts spec'd by Dan D'Agostino (of Krell). Pop the hood and look.
  11. qguy
    qguy Super Member
    1,366
    Manila, Philippines
    Cause I could not find the 4004 :( in my area and the 2004 is available
  12. qguy
    qguy Super Member
    1,366
    Manila, Philippines
    If you pop the hood, the SX-1250 will win :)
  13. spark1
    spark1 Super Member
    1,924
    The Great Midwest
    I was asking silentnet why he considered it a poor choice. Looks to me, at least on paper, that it could do a better job with lower impedance loads. The 1250 is a very good sounding (and very well-built) amp, but I don't think the handling of difficult loads was a primary design objective. For most speakers, it is a fine choice. For more difficult speakers, perhaps not as much.
  14. spark1
    spark1 Super Member
    1,924
    The Great Midwest
    To the OP: Did you ever resolve your issue with one channel of the 1250 being louder than the other? I suggested a couple of approaches for determining if the output is truly different (vs a function of placement and varying levels of room reinforcement), but never got a response.
  15. qguy
    qguy Super Member
    1,366
    Manila, Philippines
    The left channel was stronger than the right channel, which was weird cause the Right channel speakers were near the corner, which should improve the bass response. Anyways, it may have been the loose banana plugs as when i dropped a piece of cardboard and hit the speaker wires, the plugs came loose. I removed the banana plugs and now using bare wire and the sounds is balance. Will copy this post this in that thread
  16. toxcrusadr
    toxcrusadr Omelette au Fromage Subscriber
    33,988
    Central Missouri
    Here's the crux of it (emphasis mine). I have a 1250 and it does not do that great with 4 ohm loads such as the AR9s. Doesn't make it a bad amp. It just wasn't designed with that type of performance in mind.
    Keep in mind you're usually not using all 200 watts. The performance (i.e. ability to deliver current when demanded) has to be there everywhere from .01W to 200W. Some amps are better at driving low impedance loads, regardless of volume setting. It's like comparing a bread truck to a sport sedan. They both do things they were designed to do, but they don't necessarily do other things very well, regardless of what speed you're going.
  17. savatage1973
    6,841
    THANK YOU!!! My point was never to "dis" the SX-1250--it is a very competent receiver, but it was never intended to drive speakers like the OP has--or my Apogees, Infinities, or Maggies--all of which are "difficult", even for a good amp. It would blow the doors off with my JBL or Klipsch (or CV's, but I don't have any right now).
    I am not into receivers (per se), but I have a Yammie CR-2020 and CR-3020 and wouldn't expect them to drive Kappa 9's.
  18. spark1
    spark1 Super Member
    1,924
    The Great Midwest
    Again, I was asking silentnet what his basis was for concluding that the Aragorn is a "sidestep".
  19. blhagstrom
    12,896
    Duvall, Washington
    Are you guys REALLY listening at 200WPC?
  20. qguy
    qguy Super Member
    1,366
    Manila, Philippines
    granted everything is ok on the 1250, if the lights on the SX-1250 are dimming, does that mean I am close to clipping ?
