I ordered it because my 1900 does not produce even sound out of both channels at low volumes, and for the first few degrees, equivalent to say, steps 1 and 2, the right channel doesn't come in unless I turn it up higher, then back it down, and even then it's pretty touchy. It's pretty annoying.
The previous owner said that a few months ago, he replaced the volume control with a part sourced part directly from McIntosh. I can tell that the part that McIntosh supplied him is a PEC. So you'd think it should be working correctly, but it isn't. It's either a design that is just as bad as the original, or its defective. I know PEC pots are very good pots, so I'm not sure what to expect with the new one. I ordered it in a "what the heck" moment.
