1964 The Fisher Regent - to Buy or Not?
Discussion in 'Fisher' started by Kasanay, Mar 5, 2017.
  1. Kasanay
    Kasanay Active Member
    153
    53207
    I have an opportunity to buy a nice looking Regency, but before I do, I'd like to get some opinions.
    From what I have read, this unit has a 400-CX-2 preamp, a R-200 tuner, and a TA-900 solid state power amp. It also has the Miracord 10 TT and a Ampex 1250 R2R.
    It looks like the tuner and the preamp draw top dollar on eBay but I've only seen them as stand-alone components. Do these consoles hold their value or would I be better off putting the units in their own cases?
    I have only taken a quick look at it - I'll get a better look in a couple of days. Is there anything I should I look out for?
    I have never owned a R2R, so I won't waste any time inspecting that.
    Would this TT be something usable, or just for show? Would you swap the TT out with something better/ different?
    The price is $280. Too much? Good find? Great deal? I'm not sure.
    Any comments welcomed.
    Thanks,
  2. notdigital
    notdigital AK Subscriber Subscriber
    2,202
    NYNY
    Dude: $280?????
    Well, I don't think you wanna tell anyone where this thing is.
    And you really don't need a better look. Just give the guy the money and ask questions later.
    You sure it's $280 and not $2,800?
  3. Kasanay
    153
    53207
    Dude: $280?????
    Seriously?
    It's that good??? Cool!
    I left the place when he said he'd take $350.
    When I got home I looked it up and called him back. I said I was interested and was that the bottom price? He says "l'll take $280". I said "I'll take it". I pick it up in two days. I hope this deal doesn't fall apart!
  4. larryderouin
    21,603
    Glen Burnie Md.
    You could have only done better if you'd have gotten a PRESIDENT in the MODERN CABINET!!!! The Regent was a 2 year Model for 1963 and 1964 dropping the Executive to 3rd place in the lineup for those 2 years. '64 to 66 were the tube to Solid State Transistional years and FISHER Started at the top. Or next to it. So the TA-900 was a 1964 to 1966 1st Gen Console ONLY Amp. See below for WPC. By 1967 Model year Solid State Receivers at the Upper end of the lineup were supposedly stable enough to be able to run the Upper End consoles, Fisher using slightly modified versions of their stand-alone receivers to power their consoles.
    If you manage to get a Service Manual, epecially the TA-900 section, please, PLEASE, scan and send to Jon or Carter in the Contact Us Link at the FISHER CONSOLES Site. This is one of those RARE one's that needs to be preserved, even if it IS a French Provincial model. The Miracord is every bit as good and some say better than a DUAL of the Day (1009-1019). And the AMPEX 1250 (F-44) is one of the better 60's to Early 70's Machines. You can still get parts for it. The belts may or may not need replacing. The motor will need cleaning and re-Oiling. It's one of those big overbuilt industrial sized motors from the 50's designed to run damn near forever. There's 2-3 of each in the R2R. 12ax7, 12au7, 12at7, ex-81. All the heads and the tape path should need is some 91% Isoproply Alcohol on some Q-tips, DeMagnetizing, and you'll be ready to go. Get a few pre-recorded tapes done @ 7-1/2 and if you think CD's are great, buddy you don't know what you're missing.
    The FM200 and the 400CX-2 in the console are the same as the stand-alones except for the rubber feet (lack of them). I would get them cleaned up, rehabbed, and in the case of the FM200B, a full alignment. The TA-900 is the unknown here. Apparently it's the largest Hybrid amp FISHER Built and it's a mystery for the most part. We know it was used only in the 1964 to 1966 President, and 1964 Regent II. Supposed to be 120Watts EIA (Total Peak Watts). RMS Approximation is about 20w-25w per Channel. But I would NOT push it THAT HARD. The Output's are Germanium, and are a bit more sensitive, harder to come by, and way more expensive than Silicon transistors so be extremely careful with it. If you get the Service manual with TA-900 Section, Fred Soop might be able to help with it should any problems arise.
    Old Pic of the TA-900
    You got yourself a hell of a console. Clean it up, rehabilitate it, get it all working and USE IT! Use the Tape Deck, Use the Miracord.
    The manuals for the Miracord and the AMPEX are available on HIFIEngine and VinylEngine. You need to register but it's free.
    KentTeffeteller likes this.
  5. walyfd
    walyfd Well-Known Member
    689
    Northeastern PA
    All I can say is DAMN!!! Worth every penny of $280. Regents don't pop up often and this is a beauty.
    Been a long time since a top - end Fisher console was "discovered".
    All the best with it!
  6. notdigital
    2,202
    NYNY
    Fingers crossed you you buddy!
    If this happened to me, I would have said, "Here's $400 if you let me carry it on my back NOW!"
    Good luck!!
  7. larryderouin
    21,603
    Glen Burnie Md.
    $2,095.00 (1964) = $16,443.87 (2017) and it looks like the AMPEX R2R was Standard Equipment.
  8. Kasanay
    153
    53207
    That means I paid about $35.67 (in 1964 money) for it!
  9. Kasanay
    153
    53207
    Thanks guys for the great information!
    I'll let you know how this comes out.
    (I may not be able to sleep tonight)
  10. Kasanay
    153
    53207
    She's home!!!
    Leland47 likes this.
  11. rufleruf
    rufleruf AK Subscriber Subscriber
    1,024
    I'm not the jealous sort - but dang! I've been contemplating a 400 CX 2 for a while and well, dang!
  12. larryderouin
    21,603
    Glen Burnie Md.
    That AMPEX should fire up with minimal Maintenance. Oil the motor, check the belts, clean the heads, and throw the switch. HUBBA HUBBA! :music:Oh yeah, Use a larger intake reel.
    Matt; you can HAVE the CX-2! I love that tuner! :thumbsup:
  13. rshep
    rshep Working my way to 1000 posts Subscriber
    724
    Sunny Phoenix, AZ
    That Ampex 1250 looks sweet. Probably full of premium tubes.
  14. bhamham
    bhamham Super Member
    1,952
    France
    Lucky dog!
  15. larryderouin
    21,603
    Glen Burnie Md.
    Probably Sylvania's. But could be Tele's if stocks were enough at the time. FISHER stopped using Tele's by 1965 as a general rule. My AMPEX A-122 came with Tele's and Sylvanaia's mixed, The AMPEX 960 came with Sylvania's an Tele's. And my AMPEX1270 came with tele rectifiers. Best bet to get Tele's were during Eisenhower to end of Kennedy presidencies.
  16. Kasanay
    153
    53207
    I haven't had a chance to dig yet.
    Maybe tonight.
  17. Andyman
    Andyman Scroungus Stereophilus Subscriber
    28,464
    15 miles North of Canada
    If you're really lucky, there will be Amperex mC1 foil getter 12AX7s in the tape recorder. I've had a few 960s loaded that way
  18. larryderouin
    21,603
    Glen Burnie Md.
    Apparently Fisher got the decks from AMPEX without tubes other than the rectumfrier. They loaded them with tubes from their stocks based on what i've seen from straight AMPEX vs. Decks taken from consoles.
  19. Kasanay
    153
    53207
    So here's a little side story:
    While I was picking this baby up, (from an estate sales warehouse) I spotted a receiver on the floor and I snatched it. It's a Marantz 2270. The owner says he'll take $75.00 for it. I bought it but then sold it to another customer before I even paid for it. Let's just say a made VERY nice proffit!
  20. asech
    asech AK Subscriber Subscriber
    286
    Mission Viejo CA.
