2001 GMC Savana, 5.7 vortec motor, 159k miles
Engine was beginning to lose small amount of coolant, but no external leak, no oil contamination or oil level change.
Brake lines failed, vehicle was parked, and was started periodically to keep battery charged.
Went out one day to start it and coolant reservoir was half empty. Checked oil , and it was at proper level and no contamination. Added coolant in reservoir, started and ran vehicle for 20 minutes....no problem.
Went out several weeks later to start vehicle. Pop hood and check coolant reservoir. EMPTY. Check oil and.....level way too high with the dreaded milkshake.... coolant contaminating oil.
Today I drain the contaminated mess, install a new filter and fill with fresh oil. Open radiator cap and add distilled water. Start vehicle and let it run without radiator cap. Coolant system is not contaminated with oil, and I am not getting any bubbling in coolant that would indicate a pressure leak from a head gasket problem.
After running for 20 minutes or so, (radiator cap still off so coolant system will not build pressure) long enough for it to come up to proper temperature, I shut it off and check again. Oil at proper level with no new coolant contamination.
So based on all the evidence I'm thinking intake gasket leak (when coolant is under pressure) , not head gasket problem.
Your thoughts?
Your thoughts?
