hurricanestv
Member
I grew up listening to these...my father had them mounted in the wood panel wall of our living room through a pair of AR's and a pair of JBL L88's. The quick scratch of a needle hitting and then some Led Zeppelin or Pink Floyd or Hoyt Axton brings back memories that no mp3/ipod/itunes/sirius will ever do.
Anyway, he put these up about 10 years ago...metal cases had been removed the whole time they were mounted and they appear to have been lost. I wanted to clean these up and get them back to attractive & working condition.
One cap on the 2215 has let go (a 100 uF cap) on the board closest to the faceplate on the far right..just got a schematic, haven't traced it to see what that board does.
I shot EchoWars a note to see what he might charge, but considering these units are low end of the line, it may not be worth restoring them. Now I'm considering following the cleaning instructions I've found here on AK, replacing that dead cap & the dead lamps on the 2215. If they sound ok, great. If not, maybe I go out and find some higher end Marantz stuff that has already been serviced to buy for him. I dunno if he liked those scoped 4-channel units, but those are the damn coolest things i've seen.
Does this sound like a plan:
1) compressor blowout with lightly moistened brush (reduce static)
2) windex & brush for grime
3) distilled water rinse
4) replace dead cap
5) water & mild soap for faceplate and knobs
6) deoxit for all controls (or non-lube contact cleaner first, then small amount of lubed contact cleaner last?)
I saw conflicting info on testing DC voltage for output on the lower power units: is it worth checking on the 2215 and 2440?
I also took the L88's for a quick check...they have some goop along the cones on the woofers that seems to have run after 30 years and I'm going to try to steam up some of the scratches in them.
guess i'm just trying to talk myself out of sending these two low(er) end units to a tech and spending big bux to get them back to spec. As much sentimental value as my father & i attach to them, i'm just thinking that it would be smarter to put the dollars into some well cared for & serviced higher end units to replace these if my little cleaning/servicing project doesn't work to my satisfaction.
4) replace dead cap
