dan001
New Member
Hi All, I recently recapped my 2230, all boards, and I thought it went well. Two problems that I previously had appear to have been fixed. The stereo light now stays on when it should, and the FM tuner now stays tuned to the selected station instead of drifting and needing re-tuning. However, I've since encountered a new problem. The right channel doesn't play properly when I first turn the unit on. It sounds like a poor connection where sound is distorted and not flowing freely. After the amp plays for 10min or so the problem goes away and it can play fine for hours. I know it's beyond the pre-out and main-in jacks because the preamp is fine when connected to my Bryston amp.
I'm no engineer and so at a loss as to what components on the amp board might be failing. Is the problem I described consistent with an output transistor problem? Should I consider changing other components? Any ideas?
Initially I was worried about what I put in for C751, but I would expect both channels to act up if that were the case. I pulled 0.47uf out of here, but thought I read somewhere it should be using 1uf film type. Not sure I got the right part. Is that orange film cap 1 or 0.1uf?
Thanks
Thanks
