Thumper
Well-Known Member
Hey guys,
Finally getting around to doing a full recap on my 2245. Also swapped out all of the lamps for LED's courtesy of Don Haywood. All boards have been fully redone with Panasonic FC's (and films where appropriate) except for the power amps, I'm saving them for last.
I've got a couple of issues, one being that it occasionally blows the 2.5A fuse on power up. There's a slight hum/buzz in the right channel and I noticed that something on the right power amp board is running a bit toasty. Hopefully I can get all of that sorted when I go through the amp boards.
After recapping the FM detector and MPX boards this thing pulls in stations like a boss now! But, alas, there is no stereo. I know the lamp works and I know the mono/stereo switch is clean. I found some posts from rbuckner and bktheking talking about adjusting the black pot (or coil) L501 on the P500 FM detector board. I tweaked it and managed to get the tuning indicator dead center when the signal strength meter is maxed. And I mean maxed as in the signal strength meter is pegged! Still no FM stereo, though.
I know the real answer is to take it somewhere to have it aligned, but in the meantime, is there anything I can try without messing anything up royally? I read about the VOC pot L301 on the MPX board, can I try tweaking that?
Rob
Rob
