NewVintageNu
New Member
So I got this 2265B at the Goodwill yesterday, score!!!
Seems to work well except for a few burned out lights and the fact the FM is weak or something. It's strange, the signal strength meter and turning indicator would only intermittently work till after I cleaned it, after cleaning the switches and controls with de-ox-it now they work full time. The tuning indicator works well but it's just not tuning or showing a strong signal on the signal meter. I had it hooked to my rooftop antenna and a station with that antenna and my Kenwood KT-7500 will just about peg the Kenwood's meter but showed about 1 on the Marantz.
Is there something in the FM signal path that could have aged and is preventing a strong signal? Or is there something wrong with the actual tuner itself? Seems to have a pretty sensitive tuner as even with the weak signal shown it picks stuff up well and some are in stereo. Sort of a PITA though cause if you turn muting on you loose most everything. To answer the question before someone has to ask it really does seem like it is a sensitive, good working tuner that is getting a weak signal, not just a meter that is reading wrong.
TIA,
Bryan
TIA,
Bryan
