Been tending to a recently acquired 2270. Thanks to the knowledge base available on this forum I was able find tips and tricks needed to replace all of the dial lamps, filter and P800 caps.
My question is related to P700, specifically trim pots R708 & R709. I came across two posts that suggested adjusting the collector voltage of H705 & H706 (clipping level) to about 17vdc via R708/R709 after changing "the usual suspects" on this board, but have not seen any other posts or comments about it.
Just want to confirm if this is the correct procedure before I make any changes. The schematic indicates 16.3v should be there and I currently have 14.3 on one and 15.6 on the other.
Second question is related to the FM tuning meter, when in a power off state the needle should be centered correct? Mine is off to the left ever so slightly and it bugs me, haven't looked at the back of the meter for a centering adjustment yet.
Thanks
Thanks
