highhosilver
Member
Hey everybody, I recently recapped my 2270 and replaced a few transistors (the two on the phono board H705 H706, and H760 on the main amp boards).
I also attempted to replaced the differential pairs H751 and H752, but after doing so, the bias jumped to 55mV and the bias trim pot had no affect on bringing this down at all. Furthermore, when listening through the headphones (and through speakers) there was a very high pitched static noise, comparable to adjusting a AM radio.
Not the best description I know, but it was obviously something that was being produced by the H751 752 transistors, because when I lightly tapped them with a Q tip it changed the frequency of the static noise.
Also, music would play at this point, but the noise was still there when music level was low.
After removing the new transistors and putting the originals back in, the bias returned to 5mv, the trim pots adjusted properly, and the static noise was gone.
So... now I need your help to tell me what I did wrong. the transistors I used were these:
http://www.mouser.com/Search/ProductDetail.aspx?R=ZTX795Avirtualkey52230000virtualkey522-ZTX795A
Were these the wrong transistors? I chose these from reviewing previous threads on replacing these transistors?
If these are in fact the right transistors, the only other thing that I could think of was that I installed them incorrectly, mixing up emitter collector.
I honestly checked and rechecked ten times, the transistor data sheets and the Marantz schematic to make sure I had everything in correctly.
Is the data sheet or the schematic wrong?
Here is the data sheet I used:
http://www.diodes.com/datasheets/ZTX795A.pdf
If anyone knows what happened here please chime in. Any input is appreciated.
I should mention that the 2270 is sounding great after putting the old transistors back in. By starting this thread I am just hoping to get the correct info so I can replace those transistors in the near future.
Thanks!
-Glenn
Thanks!
-Glenn
