Replaced the two big 10,000uF capacitors and all the caps and some diodes & relay on the power supply board (P.800).
Now one channel is 95% out. It was intermittent before and I suspect it is something in the amp board.
-BUT- I would like to verify the power supply is OK before moving on to the next board.
Could someone please recommend a few voltage check points to verify.
Thank you AK brain trust
