I have a nice 2275 here that I just re-capped. Bias and dc offset adjusted easily without issue. Sounds good until I get to about 11:30-12:00 on the volume control and then the right channel starts popping. I tried 3 sets of speakers, same result. Also tried feeding a separate preamp into the main-in on the 2275 and same result, so it has to be the right amp board. I went through and shotgunned all the transistors on that board, along with h715 and h716 zeners, and new MJ21193/94 outputs. Still clips in the right channel only. I deoxited the molex connectors also and no change. Anything else I should be looking for? The only thing I can see on the board that is questionable is one of the 5w cement resistors has been replaced by a previous tech.
