oldguy68
New Member
I am picked up this 2325 in working condition so I decided to restore it. First I went through all the boards and changed tantalums, diodes, electrolytics, the ly2 relay and cleaned the pots and checked solder joints. Then I set the voltage on P800 to 35v.
After trying to set dc offset I changed R713 on both P700 boards to Bourns multi turns. The offset for the left and right channel was set close to 0.
1 to 2 mv.
The bias on the left channel set to 14.7
The right channel bias is 1.3 and will not adjust when I turn R740. It will drop to zero when turned. I tried a multi turn here as well but did not change.
I have gone through the right board and changed resistors that were out of spec as well as new 1n4747 zeners at H716/717. I also changed the other diodes on the boards to 1n4148.
H701/702 were replaced with hfe matched KSA992's. Paste and heat shrink applied.
H703 was replaced with KSA992 hfe matched to 701/702.
After a slip of the meter probe checking voltages I shorted H708. (Not to smart)
Changed the following.
H706 to KSA1220 legs heat shrunk and crossed.
H707 to KSC2690 legs heat shrunk and crossed.
H708 to KSA940
H709 to KSC 2073
Outputs changed to MJ21195 and MJ21196
H710/713 changed to KSC 945 legs twisted with heat shrink applied.
H711/713 changed toKSA733c
H714/715 changed to 2n4923
Also changed 8pf and 100pf caps as well as replacement of the silver caps with polys.
Still can't adjust bias.
I did run it with this bias and it played ok for 12 hours.
From a previous post rcs16 replied the following.
Looks like you need some fine tuning in the bias generator ckt (H715) to increase the voltage drop across H706,707 collectors. The Vbe multiplier voltage drop is controlled by the current generated by the bias network connected to H706,707. Changing any comps will affect it.
Not sure what to do here so any help would be wonderful.
1 to 2 mv.
H708 to KSA940
H709 to KSC 2073
