2325 p700 board issues
Discussion in 'Marantz Audio' started by oldguy68, Jan 9, 2018.
  1. oldguy68
    oldguy68 New Member
    7
    Just going through a 2325 p700 board checking resistors and found that R739 on both boards is 10 ohm. The schematic is 4.7 ohm. Not sure if this was factory or second party add. Will this cause dc offset or bias problems?
  2. petehall347
    petehall347 the brandy coffee man
    24,153
    uk.. the middle bit
    if bias is ok i would leave as is
  3. oldguy68
    oldguy68 New Member
    7
    I have gone through the p700 and bias will not set.
    I have replaced transistors, caps, resistors, pots as per suggestions from AK site.
    DC offset is zero. Bias is between .1 and .2 mv and will not adjust to 15mv.
    Stumped.
  4. quaddriver
    quaddriver 120 What's per channel Subscriber
    .1 or .2mv is .0001 or .0002 on the DMM. meaning something is open and that is reading leakage. did you mean to type that as typed?
  5. Steven Tate
    2,226
    N. Richland Hills, TX
    If turning the trimmer causes little or no change, be sure the test points are correct. I'm not aware of any bias service manual errors on the 2325 like we see in other units. But no change with trimmer adjustment always makes me double check test points. I've had it wrong more than once.
  6. oldguy68
    oldguy68 New Member
    7
    I am testing at J702 and J708. The pot does not change readings when adjusted. It is a bourns multi turn pot.
    I am rechecking components again. Voltages at test points are within spec except for J702 and J708.
    Removed the pot and it meters ok.
  7. oldguy68
    oldguy68 New Member
    7
    I put the old pot back in and can adjust to 1.7mv. DC offset is at 0.
    Voltage readings at
    J702 110.3 ??
    J703 -60.8
    J704 -60.8
    J705 -60.7
    J706 +60.7
    J708 +111.1 ??
    J709 +60.8
    All readings done with outputs removed.
    Any ideas?
    Bias on left channel is 15mv
    Dc offset is 0
  8. quaddriver
    it works with old junky pot, but not with multi turn...toss ole mr meter on both pots and report back how they behave
    if you didnt do the work, are all the OTHER resistors on the bias circuit the same as spec in the SCM?
  9. oldguy68
    oldguy68 New Member
    7
    The pots test good off the board the board.
    R743 and 744 are 1.5 on the schematic but are actually 3.3ohm.
    Saw this same thing on another post.
    I changed the 10 ohm R739 to the 4.7 as listed on the Schematic to try it.
    All of the other resistors are as per schematic
  10. oldguy68
    oldguy68 New Member
    7
    After checking again I put it all together fired it. Has been going for 12 hours with no issue. Sounds great.
    I will check bias and offset again tonight.
    This is my first time working on a marantz. Not being a skilled technician the AK Marantz forum was a great help.
    Also Blue Glow you tube video's were a big help
  11. oldguy68
    oldguy68 New Member
    7
    Still puzzled as the bias is at 1mv. I have changed all the transistors, resistors, and electrolytic and film caps as well as new outputs. Also tried different pots.
    I just can't see what the problem is. Will operation at 1mv on bias for right channel have any detrimental effect? Any input would be very appreciated!
  12. rcs16
    rcs16 Super Member
    3,123
    Baldwin, Ontario, Canada
    Do you have original bjts installed?
    Looks like you need some fine tuning in the bias generator ckt (H715) to increase the voltage drop across H706,707 collectors. The Vbe multiplier voltage drop is controlled by the current generated by the bias network connected to H706,707. Changing any comps will affect it.
    See if changing R470 to a 2K multiturn pot will provide enough bias to meet spec, you want around ~30mA of bias in the o/p bjts. you have 0.22ohm emitter R's so that is 6.6mV across each R or 13.2mV across both, spec is 15mV as you mentioned.
    Make sure the bias pot is at minimum setting to start with and always a good idea to power up on dbt when you are doing this fiddling until you get it where you want.
