Soundslave
Member
Well I told myself not to do it but could not get it clean otherwise so I removed the plastic stick inside. Now I've lost 2 of the small springs. As I see it I have several options at this point.
1, Buy a switch and replace the stick. This would be the easiest solution however an exact 2325 switch has not appeared on eBay and I'm not sure which other switch would be a good replacement. The one I need has 6 contacts total 3 on each side.
2, Try and find springs to replace the ones lost. Could the springs be glued in place?
3, Use something other than a springs to supply the needed contact tension like a small wad of solder wick glued in place.
Any advice on how to best address the problem would be appreciated.
