afroaudio
I am freshening up a beautiful old Fostex Lab 300 power amp. So far have replaced the relay and electrolytic capacitors and have now pulled the 8 output T-03s which are 2SD424 and 2SB554 pairs (original Toshiba)
Checking these I have one of the 424's with Hfe of 37 (min spec should be 40) the rest are close to 50 plus or minus. The PNPs are vary between 71 and 99 Hfe.
Question are these values of any real concern here? Should I forge on with the original outputs?
I have a set of OnSemi 21193/94 here ready to swap in if need be, but checking the Hfe's on these (same batch nos) I see 3 of my 21194s are in the 40s-50s and then the 4th has and Hfe of 80!
Maybe all of this is meaningless with output transistors? I am used to matching Hfe on input differential pairs.
