Thanks for the answers.
I asked because i have an amplifier thas uses these outputs.
fortunately the outputs in my amplifier are fine( or i think so), but this amp is known to easily blow the outputs, and i want to know a replacement if the ones in my amp fail.
The amp is the silver sa-5030, i made a thread here when i was reparing it.
when i got it it was completely dead. i resoldered lots of cold solder joints, changed a fusable resistor that was open, changed almost all caps,adjusted the bias and cleaned it, because it was very dirty.
now it works fine, but there are two issues can't fix.
offset 30mv right, -30mv left. i changed the differential pair with no luck. also it have some distortion in the highs, but not very noticeable.
someone said to me that the distortion can be caused by a bad output, but i don't know how to test it. they arenot shorted, because the fuse doesn't blow, ad i got sound through the speakers. and they are not open, because can adjust the bias measurin voltage in the emitter resistors. is there another way the outputs can fail?
