34V Offset on AU999
Discussion in 'Exclusively Sansui' started by Hipocrates, Aug 13, 2017.
  1. Hipocrates
    Hipocrates Anti-Muppet
    1,578
    Costa Rica
    I took an AU-999 after several months of been rebuilt ( it was full of problems) to play it for a while, and I found that sounded really bad and have a nice thump when turn on.
    So I took it to the bench and test the offset, to my surprise the little bugger have 34 volts on RCH.
    Weird isn't?:dunno:
  2. LBPete
    LBPete Rolling Along
    11,308
    Long Beach, CA
    It's a cap coupled amp. You can't measure offset by just measuring voltage at the speaker terminals. I haven't looked at the 999 procedure recently buy typically you need to have a dummy load connected, inject a 1k Hz sine wave and adjust it to clip the + and - apexes at the same time. It's sometimes called "balance."
    - Pete
  3. Hipocrates
    1,578
    Costa Rica
    Hello Pete, all due respect, is not a coupled cap, I think you are referring to the AU-777, 505, and those.
  4. LBPete
    11,308
    Long Beach, CA
    Yup, I just looked. Here's the service manual procedure.
    - Pete
  5. Hipocrates
    1,578
    Costa Rica
    Thank you Pete.
    Curious thing, while the LCH adjust perfect, RCH stays 34v, even switching F-1159 sides.
    So far what I know is this:
    ./ Outputs are fine
    ./ Driver transistors are fine.
    So, it seems that I need to sharp my limited diagnostics skills :rolleyes:
    BLAH BLAH likes this.
  6. petehall347
    26,041
    uk.. the middle bit
    maybe resistors .
  7. Hipocrates
    1,578
    Costa Rica
    Good idea... I'll start to test on F-1231, F-1277 ad F-1230 and see what I find
  8. kevzep
    To clarify, the AU999 is not a Cap coupled amplifier. I should know I am working on one right now.
    Pull the F1209 boards out, or if you have one of the models where if you select "Speaker C" it also disconnects the pre-amp from the poweramp, do that.
    Then see what you have.
    If you still have huge offset, then pull the driver board out. Could be D801/809, at the front of the driver circuit, one or both might have shorted out...
    If you still have offset, you need to check the driver and output transistors, it could be possible with the Quasi design to lose a transistor without taking a rail fuse out...and now we are all ripping out the DC protection, it is possible to have this sort of DC on the outputs...
    Sebastien and BLAH BLAH like this.
  9. Hipocrates
    1,578
    Costa Rica
    Thank you Kev,
    I'm on it right now... I'll report later.
    I did all what you said... right now I'm checking resistors too (as I'm there anyway I'll replace some old carbon with new vishay metal film that I have on hand)
  10. kevzep
    There is one other thing to check, and that would be the filter block which the Emitter resistors are on, make sure the transistors on those are good.
    Apart from that it's just a bit of detective work and you'll find it.
  11. petehall347
    26,041
    uk.. the middle bit
    when i get such as this i first see what voltages at the outputs . if ok move to the drivers . but first noting whether offset is plus or minus .
    p.s output voltages wont be correct at this stage but might lend a clue as to where to look next .
  12. Hipocrates
    1,578
    Costa Rica
    Great, thanks for pointers gentlemen, now that I'm finished of playing with dogs I'm back to the task!:thumbsup:
  13. Hipocrates
    1,578
    Costa Rica
    Those damn emitter resistors are way out specs... I'll put some on my next mouser order.
    Thanks folks, your are gentlemen and scholars:beerchug:
