Actually he could hook up to 4 speakers @4 ohms if wired in series for a 16ohm load in that case.If he has an amp that is 4Ohm to 16Ohm capable, you can only use one 4Ohm speaker per channel
Not sure why but when he hooks it up to his carver amp it heats up and then goes into protection and Im not sure how to reduce the speaker ohms to make it work with that amp?Actually he could hook up to 4 speakers @4 ohms if wired in series for a 16ohm load in that case.
There are plenty home speakers that are a 4 ohm nominal load.
