I thought the industry was only going to deliver 4K content via streaming but now I see it appears to be available on DVD. Is this true? How do they do it without creating a new class of DVD player?
It's called UHD. It's a different format requiring a different player capable of handling the new disks.
It costs so much more to do post in 4K that right now, even if the capture was in 4K or 6k, the digital intermediate is done in 2k and then uprezzed to UHD, negating the extra resolution advantage over blu-ray.
Sorry for t confusion. UHD is capable of true 4K, but only if the source was mastered in 4K.So in layman's terms what you are saying is that this format does not actually give you 4K. It's higher than HD but less than 4K, correct?
6K? Is 4K already obsolete? Where will it end?
There are three production points to consider - capture, post production (editing) and delivery. For instance, the cameras used to capture the original image, such as Red or Canon, might be 8k. The results might be converted to 4K or even 2k for editing and color grading. Then the resulting master can be used to produce DVD, Blu-Ray (2k) and UHD (4K). If the master was in 2k, it can make a Blu-Ray with no adjustment, but must be "uprezzed " for UHD. The UHD can't be "sharper " than the Blu-Ray, though.
They are working on the next TV standard, 8k!
Funny, I thought we were trying to get away from film as it also has limited resolution!Film
Actually film has problems with resolution and it deals with how fine the grain of the chemical is that makes up the photo sensitive properties. This was a real problem back in the day when they first tried to get high resolution photos from spy satellites in the early Corona Spy Satellite project. I believe it was Kodak that developed the finer grain film substrate that allowed much greater resolution bringing in more detail in the smaller objects.Film is analog and doesn't have resolution just like vinyl doesnt have a bit or sampling rate.
Actually, film is digital (binary) in a sense. The silver halide crystal absorbs enough energy in the form of photons to chemically react (with the help of developer) or not. After development and before fixing it can only exist in one of two states. The developer either reduced it to metallic silver or it didn't. If not, fixer dissolves it out of the emulsion layer. The metallic silver particles (grain) are opaque. The concentration controls how much light transmits through any particular spot on the negative. BTW, all modern color film starts out as a B&W negative before becoming either a color negative or transparency.Film is analog and doesn't have resolution just like vinyl doesnt have a bit or sampling rate.
