60's stereo console tube amp removal
Discussion in 'Tube Audio' started by skywachr, Jun 13, 2018.
  1. skywachr
    skywachr New Member
    37
    AZ
    First off I am a complete novice in the area all things tubular but consider myself quite knowledgeable in the area of vintage solid-state audio gear. I do not however get into doing my own re-capping etc.
    I have come across a GE console stereo model Abbington from the early 60's in perfect working order in a thrift store. The tuner emits a stereo FM signal with very pleasing stereo tones given the limited 8" speaker that is in the unit. The cost of the unit is $38.
    I am very interested in making this my first tube project. I am not knowledgeable enough to understand whether there is a preamp integrated into the tuner electronics as it seems to be on board in one area of the console with the amp as a separate unit.
    Is this a viable project? Will I be able to use any of my solid-state preamps feeding into the tube amp? Would it be wiser to use the preamp/tuner section as part of this whole set up? I really don't know what I'm stepping into here. Any help would be greatly appreciated. I am going to attempt to attach a photo of the simplified schematic which was stapled to the bottom of the unit to this posting which will tell you exactly which tubes are part of all of this.
    Thanks in advance.
  2. FlaCharlie
    FlaCharlie AK Subscriber Subscriber
    783
    Gainesville, FL
    Yes, it's a viable project. It does look like the preamp / tuner is in a separate chassis from the amp. The amp is single-ended (one 7189 output tube per channel) so not a lot of power. I think this amp uses a circuit board instead of being wired point to point. You should be able to use a SS preamp with it but I'd suggest pulling the pre / tuner section too.
  3. FlaCharlie
    783
    Gainesville, FL
    Dandy likes this.
  4. skywachr
    skywachr New Member
    37
    AZ
    Thanks Charlie. I was mistaken. It's actually an RC4238 model. The Abbington seems to be the RC4231A which may be a different style cabinet for the same model. I haven't compared the drawings yet as I'm looking at this right now on my phone. I could find nothing related to that exact model number in a web search except for ads in old newspapers.
  5. skywachr
    skywachr New Member
    37
    AZ
    The model I'm looking at (RC4238) has the same tubes as in that post for the RC231A you referenced.
  6. FlaCharlie
    783
    Gainesville, FL
    The Sams I linked to lists several model numbers including 4238A. I'm sure the addition of the 'A' suffix is a fairly minor revision and the schematic should be essentially the same. The different model numbers may refer to the console itself and reflect differences in cabinet styles or other features such as different record changers.
  7. skywachr
    skywachr New Member
    37
    AZ
    Once I was able to see the whole Sam's I saw the 4238 reference. I was specially interested in the photos which showed how he isolated the control amp and amp pieces together on a board to hopefully make it usable. I have a hold on the piece and will definitely go for it. Thanks for the encouragement.
    By the way, the outputs to the speakers look like mini rca plugs. Is there a term for these?
  8. cubby01
    cubby01 aka Buck
    9,753
    Kansas City area
    RCA connector. I doubt its actually 'mini' though it may look it at first glance.
  9. skywachr
    skywachr New Member
    37
    AZ
    Thanks. That did occur to me. Just not as beefy as what I'm used to seeing and handling all the time. No separate ground connector. Just a common ground running all over. Makes sense that is possibly where the term common comes from.
  10. fredtroy
    fredtroy Member
    83
    Have fun with your tube endeavor.
