7 inch reel replacements
Discussion in 'Tape' started by ConfuciusSay, Oct 2, 2018.
  1. ConfuciusSay
    ConfuciusSay AK Subscriber Subscriber
    329
    North Myrtle Beach SC
    I have a bunch of prerecorded reels with less than perfect reels that cause the tape to scrape against the side occasionally. I’d like to transfer them to new plastic reels to protect them. Are there any that are recommended or should be avoided? Most of them are operas by the way so I need them to have smaller hubs. I saw some new production reels online but I’m not sure I can link them without breaking rules.
    Thanks for any information - I’m more of a vinyl guy and feel lost with tape most of the time!
  2. embrown057
    embrown057 Active Member
    226
    Apollo Beach,FL
    US Recording is a good source, more expensive than EBay but you will get a quality reel. Are all your reel that warped or having a problem with reel table alignment?
  3. MRL_Audio
    MRL_Audio AK Subscriber Subscriber
    6,177
    St. Chuck, MO
    +1 on USR.
  4. ConfuciusSay
    329
    Thanks guys will check that out. A reasonable question - I’m pretty sure that it is the reel itself because the majority play fine and I can look down the reel and see that it is no longer perfectly straight. Again kind of a newbie with reel so anything’s possible!
  5. ConfuciusSay
    329
    I see plastic reels that come in a set of 2 for 20 but are out of stock/production. Any old or new old stock that are strong contenders?
  6. dhnash
    dhnash Well-Known Member
    579
    Wildwood, MO
    ConfuciusSay likes this.
  7. quiberon
    quiberon New Member
    42
    Yorkshire, United Kingdom
  8. Blue Shadow
    22,295
    SE PA
    If the tapes rub on one side, on one reel table, feed or take up you might be able to adjust the reel table height to stop the problem. Ideally, the reel tables will pack the tape in the center of the space and this is easy to check on the take up reel, a bit harder on the payout reel. Tables can be adjusted but if there is an arm with a tape channel in it, it may have been moved from proper alignment. Just stuff to consider but you did say your old reels weren't in good shape.
  9. Skylab
    Skylab Altimeter reading zero Subscriber
    5,480
    Chicagoland
    How many do you need? I can send you quite a few for free if you just pay for shipping.
  10. ConfuciusSay
    329
    Wow that is very very nice - will pm!
