771 Power Supply Board
LBPete
Rolling Along
Subscriber
Does anyone have a picture of the foil side of board F-1500C? I had a little brain fade when re-capping it. There was a glass diode that connected across the solder pads of C03 and C04 and I didn't document it's orientation.
Looking at the schematic and the board, it seem that Sansui relocated ZD02. There are unused holes in the board for this diode and I'm guessing they moved it to the solder pads in production. If that's the case, the cathode connects to the + lead of C04 and the anode connects to the - lead of C03. I'd just like to confirm it before I solder it in.
This unit is actually an 8010, the black trim version of the 771 if it makes any difference.
- Pete
  • 771_PS Board.pdf
zd02 anode to ground . cathode to c04 + .
basically the same electrically as anode to c04 - cathode to +
That's what the schematic indicates but I've been led astray by Sansui schematics. I'd like to confirm it on an actual production unit.
- Pete
