ncwalz
Mostly just a lurker
I'm in the process of restoring a Fisher 800B. I replaced most of the caps and resistors. Still waiting for new electrolytic cans from Hayseed Hamfest and some new tubes including output tubes from Jim McShane. Everything was going well until....
I decided to remove the noose and adjust the phase investor pots using the quick and easy method outlined in the sticky. I've done it a couple of times before and was in a hurry and kind of careless. After completing the adjustments, I forgot to remove the short from the positive terminal of the electrolytic can to ground that supplies the phase inverter B+. Of course I simply powered up the receiver quickly on the variac without the use of a dim bulb tester and was greeted with a loud hum and magic smoke coming from a resistor on the same electrolytic can.
After realizing my mistake I shut everything down quickly. Upon restarting the receiver I have noted that although it is operational, the sound on both channels is very distorted. I'm hoping the damage is mostly to the electrolytic can and resistor which are going to be replaced, but would appreciate any suggestions as to other checks I should make.
Thanks
Thanks
