If you measured the DC offset at the speaker terminals while it was in protection, the result is meaningless. The protection relay disconnects the amp output from the speaker terminals. Take the wood cover off, set it on it's side, transformer side down and remove the bottom cover. There is a blue and a gray wire coming off the power supply board that go to the protection board. Measure the DC voltage between each of those wires and the steel chassis.
On the driver board there are 4 150 ohm fuse resistors that frequently drift out of range. Be sure you check them.
Please use the forum search tools and read previous posts on this topic. All of these steps have been posted many, many times.
- Pete
