Blue Shadow
Waiting for Vintage Gear from this century
This is an unrestored unit that has been worked on before. Seems to be in good shape as far as those previous repairs.
I was setting the bias the other day and that didn't go well. I was successful in getting the unit to stay in protection and now I need to troubleshoot the unit.
I'm checking side to side on the driver board and found that one of the TR-05/06 pair is bad now. These B649A seem to be getting replaced with KSA1220AYS, replace both?
The common failed fusible resistors R33/34 are good, one having been replaced in a previous repair, but one is low at 172Ω, the other 181. Any reason to be concerned about these? And if they need to be replaced, do they need to be flameproof resistors?
Other than the two VD diodes, any other components that need to be swapped on this board except the 'lytics?
I have read in another thread that the unit can be tested with the driver board out of the unit as long as the 4-pin connector is attached at the top of the board. Is this true?
Maybe I can get this one back to working.
