Duke, this alignment requires an am/fm signal generator, a scope, and voltmeter. There are 4 adjustments (2 for am and 2 for fm) for each end of the dial. That being said, the first thing they tell you to do is ensure the pointer is at 0 when the tuning capacitor is fully closed. If its not at 0 with the capacitor closed, and its off in the same direction as the station freq, all you may have to do is move the pointer. That is fairly easy, carefully remove the string from the pointer move it in the direction you need and reattach the string.
If you have any other questions don't hesitate to ask.
