howdy folks, I bought some led tv's with cracked screens a while back and this particular one (a 26") was the easiest one to work with for this cause of its housing, tell me what ya think, will it work, will it burn itself out? lets make some predictions!
in this shot we see 4 strips of 8 led's each, I concluded the strips run on 24v so im using a sony 24v 2.2a adapter i had on hand, the bridge that connects them however, connected them in series, so I had to ditch that and wire them up like this. the wires are soldered in and then taped to ensure they dont touch the metal.
however, I wasnt sure if steps needed to be taken to protect the leds from over current, I had this uninformed feeling that they didnt, it just seemed to me like they only pull what they need, but I needed to be sure
490mA, nice! that works out to 15mA per led.
this is some white reflective thing that was already in it, i simply stuck it back in
and it also had this diffuser bit, not sure im going to keep that yet so it is just lightly taped on for the moment
I turned all of the room lights off for these next 2 shots, gives you some idea of how bright it is
leaned it away from the wall a bit
other things I still need to do are find an adapter plug so i dont have to cut the cord on my sony brick, im also going to put a 1 amp fuse in there, i figure a dead short will go to max load and a 0.5 might pop when there isnt a problem since the load is so close to that, i might also play with one of my dimmers and see how that works out..
I havnt checked to see what the brick pulls from the wall during all of this yet but plan to, hopefully not very much.
so what do ya think, will she grow lettuce? i think it will, lettuce doesnt seem to care too much what kind of light it gets as long as it gets plenty of it, this certainly has plenty to give
