zenarrrow
Well-Known Member
So, when I power up my SX 980, Everything works good. I can tune into AM/FM play a TT use my CD player through the Aux inputs. I have recently used the monitor with a Bose EQ so every thing is working properly. 2 issues I will try and solve the first one before I move onto the 2nd problem.
The only Indicator light I am getting is the STEREO light, when indeed I am dialed in on a good FM station. When I flip into Phono 1, Phono 2 Mic, Aux, AM I get no indicator lights. (Main lamps, all 3 working)
Everything is running properly just no lights. Bulbs are fine as I have pulled them out and inspected them.
I notice that the Stereo Indicator blue wires are running to the Power Supply board (?) and all the other indicator light wires are running to GWS 125 Function and Equalizer board. (?)
Could something be awry with that board where all the other wires are running?
2nd issue (in case related) right power meter not operating (If not related I would like to address this separately).
