Bi-amping benefits were being able to place filters before the amps, which were less costly to build, reduced IM distortion, removed power absorbing passive crossovers insuring better coupling between drivers and amps/ If you leave the passive crossovers in and don't use an electronics crossover, the only thing you might gain would be having a choice of using SS or tube amps for a different sound. Altec JBL EV and Bozak loved bi-amping. Bozak for better woofer transient control, and the ability to use either SS or tubes for the mid range and highs and gain efficiency. When Altec, EV and JBL went from horn woofers to ported to reduce size they lost a lot of sensitivity. And to make up the difference and maintain quality Bi-amping was a great answer. Concentrate big power where needed in the bass and use less power for the HF horns, This lowered IM distortion and helped control the woofers. Built in Equalization was added when Altec, JBL and EV changed horn designs to increase directionality, but reduced HF output. As Klipsch stayed with their original designs preferring to give up low frequency response versus high efficiency, bi-amping didn't make much sense. The horns weren't big enough to extend the low range anyway. Now when I used Split La Scalas with MWM-s woofer boxes in discos. The La Scala Hanging and the MWM on the floor using Altec or JBL woofers, Bi am- ping with a 70 hz crossover made perfect sense. The MWM had to be filtered at 35 hz with Eminence woofer, but with JBL and Altec woofers The bass could be extended below 30 HZ and 200 to 300 watts applied with out issue. 100 watts for each La Scala was more than needed. So two Mac 2250/2255 or 7300 on the bottom and one 2250/2255 or 7155/7200 on top made for ideal reproduction in smaller clubs and discos. When there wasn't enough room for two or 4 MWM, then Lansing or Gauss ported boxes with dual 18's or 15's were installed with dual Mac 2500 or 2600 amps. Later on new installations were made with QSC amps with Power Guard when Mac quit selling their Rack mountable units and concentrated on consumers and audiophiles.
