A few more DIY Tube amp Questions
Discussion in 'DIY' started by H713, Feb 12, 2018.
  1. H713
    H713 New Member
    17
    Wisconsin
    After a bit of pondering after my last post, I've got two designs in mind. I'd prefer not to spend the $250 on a pair of ST-70 output transformers. I'd like to keep the output transformers under 200. I'm trying to decide between building an "ST-70" with Edcor transformers (probably have to be a 5k or 6.6K) or building this design, also with Edcor transformers:
    http://diyaudioprojects.com/Schematics/Mullard-EL34-Push-Pull-Dynaco-A420-Tube-Amp-Schematic.htm
    Alternatively, I could scrap the EL34/6L6 idea, buy a pair of ST-35 transformers and build a 6BQ5 amp. I'd really prefer the extra power of the EL34, but I'd be open to that idea if it would sound significantly better. My speakers are 87db efficiency if I remember, so I think a 17W amp would be pretty small.
    Unrelated, anyone know the power transformer or B+ voltages in a Conrad Johnson PV10?
    Thanks guys, I'm still a little new to this. Sorry if this post is a bit redundant to my last thread.
  2. Shadowdog
    Shadowdog Super Member
    2,999
    Flin Flon, Manitoba
    ST-35 used the Z-565 transformers which are said to be better than the ST-70 transformers by many and the ST-70 are better than Edcors PP from lots of reading. It's about the interleaving when winding a transformer and the ST-35's Z-565 has the most, which improves the high & low frequencies along with lower distortion. It takes more time to do it properly so the cost is higher for the ST-70 verse the lower priced Edcor ones.
