Still Distorted
I’m ready to throw in the towel. The G-20000 still has distorted output from the right channel.
Last weekend I finished cleaning the switches and pots and reassembling the pre-amp/tuner unit. Over the course of the previous week, I gave the controls four cleaning cycles, two with DeOxit-5 and two with Pro-Gold. The chassis went back together without any drama. I was a little concerned about restringing the dial cord but it was pretty straight forward. The service manual has a clear and detailed diagram for the dial cord. (I just wish the schematics were that clear).
With great optimism I hooked everything up and turned it on. The left channel sounded great but the right channel was severely distorted. Worked all the switches to no avail. The distortion was very consistent. All of the previous erratic operation was gone and there was no scratchiness from any of the switches or pots. But the right channel was consistently distorted. I switched the leads that connect the audio output from the pre-amp/tuner to the Amp to see if the problem was in the pre-amp/tuner or the amp unit. When switched, the distortion remained in the speaker connected to the right channel. Damn.
That was last Sunday. This week, I tore back into the amp. The power supply boards, which have the output relays, also have three of the infamous fuse resistors. All three fuse resistors on the right side power supply board were over spec. One by a magnitude of 5. Could it be this simple? I replaced all of them on both power supply boards.
I also wanted to check the output relays again. It is interesting how the output relays are wired, each power supply board has two, DPST relays. One for the “Speaker A” output and one for the “Speaker B” output. The two poles of each relay are connected in series so the output signal is routed through both sets of contacts. I carefully checked the continuity of the signal though it’s entire path including all the solder joints for the relay. Clean as a whistle. Hooked everything back up and have the same distortion in the right channel.
That’s where it stands now. Left channel blasting the blues courtesy the Long Beach Jazz station, KKJZ and the right channel sucking wind.
If I can’t come up with anything else, I’m ready to pack it up and seek professional help. Northridge Electronics is about an hour’s drive to the north or Mike Zuccaro is about an hour and a half drive to the south.
- Pete
