Sorry to come late to the party, but I can’t resist jumping in on this one.
Horsepower VS Torque, it’s a little like Ford VS Chevy. They both have advantages and disadvantages. As has been pointed out in some of the posts, Torque is a measure of the force applied or “work” done by the engine. Horsepower is Torque over time. In other words, how fast you can have it. You can think of it as the difference between a punch and a shove. Both may have the same net force, but the punch hurts more because it concentrates that force in a very short time. In terms of the two engines in the original post, the one with the highest torque is the more powerful engine.
Which is better, Torque or Horsepower? That depends totally on what you are trying to accomplish. If you need to move a freight train, speed becomes secondary to force. If you only need to move a little rice rocket, horsepower is where it’s at. There are references to drag racers. Here you need to move a relatively light vehicle as fast as you can. There is another factor, gear ratio. A top fuel dragster needs to be geared for 300+ MPH so you can imagine how tall a ratio is required. (Think about starting you bicycle in its highest gear). You need enough torque to get off the line pulling that gear ratio, then tons of horsepower to get the low ET.
As far as RPM for maximum horsepower or torque, that is dependent on several factors, charge density, fuel density and the length of the crank throw. Charge density refers to how much air and fuel you can get into the cylinders at a particular RPM. Assuming your fuel metering system keeps the air fuel ratio correct, in a naturally aspirated engine, (no turbo or supercharger) you are totally dependent on the difference in air pressure between the ambient air and the cylinder. A lot of design time is spent on maximizing this transfer efficiency. The reality is, the lower the engine speed (RPM) the longer the time to charge the cylinder. At higher engine speeds, there is just too little time to get much air into the cylinder so the power produced drops off.
An engine with forced air induction, (turbo or supercharged) has an auxiliary air pump pushing air into the cylinders. This improves the transfer efficiency and greatly improves the charge density, but the dynamics outlined above still hold.
An engine’s maximum Torque will occur at the engine speed that provides the best cylinder fill. This occurs at a low RPM because there is simply more time to fill the cylinder. Maximum Horsepower will occur at some balance point between cylinder fill and RPM.
There are a lot of references to diesel engines. These engines produce higher Torque for a lot of reasons. First is fuel density. Diesel fuel simply has more BTUs per unit than gasoline. In other words, all other factors being equal, burning a pound of diesel fuel produces more power in the form of heat, than burning a pound of gasoline.
Next there’s compression ratio. This is the volume of the combustion chamber divided by the volume of the cylinder. Diesels use the heat generated by compressing the air in the cylinder to ignite the fuel. To do so, they generally have compression ratio twice to three times as high as a spark ignition gasoline engine. Higher compression ratios improve the amount of power produced. (The high compression ratios also contribute to the characteristic clatter of diesel engines.)
Another factor is the length of the crank throw. Industrial diesels tend to have long strokes and relatively small bores. The longer crank throw is simply a longer lever arm working to turn the crank. A long crank throw produces more Torque than a short throw but generally can’t turn as fast. There are short stroke, high rev diesels but they are generally used in passenger cars.
One last thing and I’ll get off the soapbox, Volts and Amps. I’ve always thought of Amps as the quantity of electrons flowing through a circuit and Volts as the force moving them. It’s a little different than Torque and Horsepower because the time factor is fixed at the speed of light. So no matter how much voltage you apply, you can’t increase the speed, but you do increase the overall power, (Watts).
- Pete
