62vauxhall
Super Member
It came factory mounted on the Dual changer contained in a Grundig all-in-one - all I kept was the headshell. The cartridge was a "snap mount" of which I've seen several but those were one or another of the "75's".
I no longer have any Dual's new enough to accept TK-24 (or similar) cartridge carriers so I removed the cartridge, ground down what had to be ground down, and epoxied it onto a BSR McDonald 810 slide.
Not looking for stylus compatibility advice. What is in it, I believe, is an aftermarket (but with the tie wire people are posting about) conical (?) that looks serviceable under a USB microscope and sounds fine while in use.
Google searching DM95 Type G produces little so I'm wondering if my guess is correct:
D - means factory fit to a Dual turntable. Or Deutsch.
M95 - what it is - namely a Shure M95
Type G - is what's a bit puzzling. I thought it could mean "guard" as the cartridge does have a clear stylus guard or Grundig as it was a Grundig unit the Dual was part of.
I also have a garden variety Shure M95 and it too has a guard but just a plain jane black one. Not a fancy clear one like the DM95 that looks almost as if it's intended to be a magnifier.
