A simple one- your favorite build/style of TT ...
Discussion in 'AK Polls' started by thedelihaus, Oct 21, 2007.
Your favorite build style/approach of TT...
  1. Direct Drive
    52.6%
  2. Rim Drive/Idler Wheel
    9.7%
  3. Belt Drive/Endless TT
    40.0%
Multiple votes are allowed.
  1. thedelihaus
    thedelihaus Nocturnal transmissions
    29,301
    Boston Area, Massachusetts
    Allright,
    This one should be pretty cut and dry.
    Your favorite TT style, in general terms-
    1) The direct drive, controlled by a center-mount (or close to) motor, where the platter is hooked through a series of intricate gears mounted over the motor and directly in the center of the turntable.
    2) The rim drive/idler wheel turntable- a TT that utilizes an idler wheel that presses/locks up against a turntable's inner rim to spin the platter.
    3) The belt drive/endless TT. This unit runs on a rubber belt, which wraps around a motor shaft (the motor usually isolated in some way from the platter), and then to a recessed inner rim of the turntable platter.
    So, what say ye, and why?
  2. marantzfan
    marantzfan ... Subscriber
    8,058
    Peoria, Arizona
    It's awful late there in Mass isn't it?:D
  3. OvenMaster
    OvenMaster RIP Mommy 1935-2018 Subscriber
    11,431
    Area Code 413
    Some of us are still up.
    I voted belt drive. I like the isolation from the motor a flexible belt provides. It's also easier to replace a belt rather than an idler wheel.
    Tom
  4. marantzfan
    8,058
    Peoria, Arizona
    I put direct drive, as the best tt I have ever owned (my Kenwood KD-750) is direct drive.:thmbsp:
  5. HalM
    HalM New Member
    11
    TT pushers
    After cleaning approximately 14,987 Gates TT's through the years
    and scrubbing stylii, hosing off the nicotine grunge and putting up with
    #10 axle grease on the bearings I voted for idler.
    The DD story makes a pulse every time the electronics open the gate for horsepower to the slab. Can YOU feel the burn?
    Rubber bands turn to cheese in free air. Fuhgeddaboudit!
    So either we use a water wheel where the weight of falling water moves
    the turbine paddles or we're going for the idler. The RtR decks have idlers, but they're on the take up, I know. As long as Parts is Parts we should be able to get wheels, neh? Being inside the slab keeps greazy fingers off the business end, too.
    Hal
  6. toomuchvinyl
    toomuchvinyl AK Subscriber Subscriber
    337
    My own private Idaho
    Belt drive is my choice too. It's just so freakin' simple. Both of the DD tables I have owned finally got to the point that I couldn't adjust to a steady speed (mind, this was when they reached 20+ years of age), but my belt drive tables have been reliable with only a couple of belt changes and attention to lubrication.
  7. merrylander
    merrylander AK Member
    20,733
    Glenwood, MD 21738
    Direct drive (Yamaha PX-3) and belt drive (Rega Planar 2).
  8. thedelihaus
    29,301
    I like the simplicity of the belt drive, but my favorite players have been Direct Drive.
    So, in theory, the belt drive units. In practice, the Direct Drive.
    Never heard an idler wheel model, but have heard great things about them. Seems it may be thee best choice, but without personal ecperience, I dunno.
  9. Fast_Eddie
    Fast_Eddie Upper-middle fi
    7,336
    Denver Colorado
    I went direct just because the best table I've heard are DD. I like my SL 1200 a lot. I like it better than my friend's Rega. But I'm not really being fair. I haven't ever owned a really good belt drive.
  10. thedelihaus
    29,301
    Eddie,
    what model Rega?
  11. cubdog
    cubdog banging through drywall Subscriber
    21,349
    Oregon IL.
    I'd like a working TT.
    cubdog
  12. Robisme
    11,904
    Martinez California
    Looks like I just put DD up by 1.:yes:
    Rob
  13. vinyldavid
    vinyldavid Proud Jaguar Owner! Subscriber
    16,468
    St. Louis
    All I have owned is DD.
    I probably want to change my answer when I buy a Dual
    :D
  14. Fast_Eddie
    7,336
    Denver Colorado
    I believe it is a Planar 2. He had quite a bit of trouble with it. Belt, then bearing grease, then some weird allignement problem with the new belt. It sounds fine, but it's a little whisp of a thing. My mighty Technics could fall on it and not notice.
  15. Gohan
    Gohan Super Saiyan
    3,264
    Calgary, Alberta, Canada
    I have to go with direct drive
  16. 240sx4u
    240sx4u Lunatic Member
    10,817
    Madison, WI
    Oracle belt drive
    Evan
  17. www.records
    www.records Quality over Quantity
    5,850
    Joplin
    I can't say that I have a favorite. There are excellent and poor examples of all 3 drives. I don't own an idler, but would love to have an old Garrard 301 or modded Lenco 75. I guess if I HAD to pick one, I pick DD for the low wow and flutter, speed consistency and general no fuss.
  18. Doug Olitsky
    Doug Olitsky My kids enjoy McIntosh!
    742
    Sea Cliff, NY
    Lenco gl75
    also like my 2 thorens td-125's
    but there is something about an idler in a 75lb. base
  19. Brian
    Brian An Old Geezer
    16,351
    Toronto On Canada
    Belt drive for me. TT for me is the Marantz SLT-12 or 12U. When 1 of these is working there is nothing that can touch it. Next of the list would be the Empire lineup, any of them.
  20. Mr. Orange
    Mr. Orange Flat speakers rule!
    556
    Northern IL
    Considering my choice of TT I go for belt drive. :thmbsp: It just doesn't get any easier. :yes:
    :music:
