depending on where you use it, it may not matter:
1. coupling: lowers the f3, allows more bass (or lower frequencies), subject to feedback loop design
2. power supply: adds capacity, energy joules, subject to overdraw of secondary transformer/rectifier (tubes)
3. bypass: depending on where this bypass is. PS: OK, elsewhere -depends on design such as in cathode bias
4. blocking output, generally OK
5. feedback - not likely for this value unless it's an off-the-wall-design
