Accuphase P-300 Front Panel Door Parts
Discussion in 'Kenwood-Trio/Kensonic-Accuphase' started by mea2112, Apr 14, 2016.
  1. mea2112
    mea2112 AK Subscriber Subscriber
    1,256
    Lansing, Illinois
    In the process of removing one of the narrow metal pieces attached to the faceplate to replace an incorrect screw, I accidentally lost the nylon pieces, the springs and the small washers that are attached to the front panel door.
    Any idea if those pieces could be replaced?
    Thanks for any help,
    Mike
  2. EchoWars
    EchoWars Hiding in Honduras
    28,416
    Kansas City
    Spring: http://www.amazon.com/Compression-S...TF8&qid=1460613064&sr=1-1&keywords=B005S4E5NQ
    Another Spring Source: http://www.springsfast.com/part_detail_compression.php?part=C04-024-010
    Nylon ball: http://www.usplastic.com/catalog/item.aspx?itemid=36671&catid=804
    Nylon washer: http://www.amazon.com/dp/B000FN1560/ref=biss_dp_t_asn
    These washers are just about too thick, even at 0.020". If you have an Ace hardware nearby, I think they carry a thinner one in their small parts cabinets.
    Each side gets two nylon balls, one spring, and one washer. I use a Teflon grease on 'em at install.
  3. mea2112
    1,256
    Lansing, Illinois
    Thanks again EchoWars! I was really hoping you had some sources on those parts.
  4. IBCNU
    IBCNU AK Subscriber Subscriber
    55
    Here are the parts for the door : (1) Nylon Washer Left Side (1) Spring And (1) Ball Right Side
