Accuphase P-600
Discussion in 'Kenwood-Trio/Kensonic-Accuphase' started by Ds2000, Feb 11, 2017.
  1. Ds2000
    Ds2000 Oh THOSE speakers. Subscriber
    5,257
    New York City
    So here is a journey related to this amplifier. It sat for 15 years in a shop, my buddies shop. He was never really able to get to the project beyond perfunctory looks and prodding. So I finally got to getting it back as his abilities are something of yesterday. Tom B, this is headed to you. Follow the story here as it should be interesting. I cleaned it up thoroughly today.
    It has a new transformer I installed while working at CSA, but the startup circuit is not in good shape after a spike, or this is what I was told. I'll look forward to it working again.
    IMG_4140.JPG IMG_4139.JPG IMG_4138.JPG IMG_4137.JPG IMG_4136.JPG IMG_4134.JPG
    slimecity likes this.
  2. FootFungus
    FootFungus Super Member
    1,118
    Dallas
    Do you have any close shots of the circuit boards? I've been underwhelmed with the construction on the lower/mid-line Accuphase units. I've always hoped their statement amps were more substantial.
  3. nj pheonix
    10,166
    New Jersey
    I know nothing about it but it looks pretty industrial (read built like a tank) to me!
  4. Ds2000
    5,257
    New York City
    Boards on cards.
    Strack likes this.
  5. FootFungus
    1,118
    Dallas
    Thanks. Much better PCBs than are what are in my P300L and V.
  6. Ds2000
    5,257
    New York City
    All glass epoxy, heavy traces, etc. It's a very well put together amp.
  7. nj pheonix
    10,166
    New Jersey
    That's a lot of chips:idea:
    slimecity and Ds2000 like this.
  8. Ds2000
    5,257
    New York City
    All related to the 12 bit A/D converter for the digital metering system. The rest of it is a linear AB amp, hand built with discrete components.
  9. FootFungus
    1,118
    Dallas
    Are the drivers bipolar, or 2SK405/2SJ115?
  10. Ds2000
    5,257
    New York City
    Not entirely sure, they're difficult to see, and the schematic is still at the old techs place.
  11. FootFungus
    1,118
    Dallas
    The pictures in the Accuphase show Hitachi 2SK400/J114. Very similar devices to the 2SK405/J115, with better Vds (+-200).
  12. Ds2000
    5,257
    New York City
    Those are they.
  13. Ds2000
    5,257
    New York City
    The main branding on the transistors are NEC, Hitachi, and the outputs are Sanken.
  14. Alan0354
    Alan0354 Super Member
    2,735
    Bay Area
    It looks like to have 4 pairs of Sanken 2SC2922/2SA1216 type of big transistors on each side. You have schmatic for the power amp?
    It's a very nice high end amplifier.
  15. Ds2000
    5,257
    New York City
    There's 14 of the Sanken transistors in the output section per channel. I do have the full schematic and parts list, but it is in the morass back where I picked it up. I'll need to beg, borrow, and steal to find a new one and the SM if it's lost.
  16. Ds2000
    5,257
    New York City
    Interestingly, in some ways it is similar to the Onkyo M-510 I have, but then it is also a world apart. The Onk kills it in sheer ability and power supply, it weighs nearly twice the Accu, but they are rated the same per channel at 8 and 4 ohms.
    Now the Onk will do 1,200w into 1 ohm continuously, 2,100 peak because of its dual 1.2 kva transformers, the Accu needs one to switch in the low impedance circuit to achieve around 450w into the same load.
    No dismissal, the Accuphase is one very nicely built machine.
  17. Alan0354
    2,735
    Bay Area
    I just got the manual for it and has the simplified schematic. Really looks like a very high end power amp. Must be very expensive. Those transistor are very powerful ( much better than the TO-264) 7 pairs works as good as 10 pairs or more of the regular transistors. Clever they use FET as driver. Here is the link to the manual:http://www.accuphase.com/cat/p-600en.pdf
    The circuit has a lot of similarity to the amp I design, but I use all BJT instead of mixed FETs. I use current mirror load on the IPS but the P-600 use resistor. But the P-600 use cascode VAS on top of darlington VAS, I only use darlington, no cascode. The one that is better is P-600 use 7 pair of the superior transistor. I use 9 pairs of regular MJL1302/3281. The P-600 win out on this.
    You going to keep it after fixing it?
  18. Ds2000
    5,257
    New York City
    I am not sure. I may keep it, it is a really nifty piece of audio history, and something I lusted after as a kid. At the end of it's run, it was $5,000.00+
  19. Ds2000
    5,257
    New York City
  20. nyhifihead
    nyhifihead Well-Known Member
    771
    long island NY
