Thank you all for suggestions! Checked out the Richileau site, About the closest I could get was a "lift off" hinge. I guess hinges for turntables are pretty exclusive in their design. It would be helpful if they only opened a little past 90 degrees, were able to separate without using tools, would hold at whatever degree you have opened it at, etc. I think probably the best solution may be modifying the lift off hinge. I would have to come up with some sort of stop so when open it wouldn't continue past say 110 degrees.
I have a Thorens turntable with the hinge pins, didn't think about trying that. Hmmm...
This AR turntable came out of a pawn shop and was basically functional. Gig Harbor Audio (Gig Harbor, WA) made the custom dustcover and is tall enough to allow playing a record with the cover closed. I have put a lot of work into this turntable and I think it looks great. I buffed and polished the platter to a high gloss mirror finish, painted the metal top plate a gloss black and left the pebble finish. Cleaned up the tonearm with some never-dull. It all looks great with the exception of the cartridge shell, it is still stock. Maybe that is what gives it it's charm. I have seen where some have modified the tonearm to accept a SME type headshell, little too ambitious for me. What I really like about these simple turntables is their ability to isolate feedback. Impressive that you can thump the table with your finger and nothing but music is heard over the system.
