Okay so I cracked them open and was not impressed by the woofer with a 4W nominal rating and also that it was stamped "low ef" :thumbsdwn: However the tweeter makes up for it, it is very similar to a soft dome from the Minimus seven, in fact I could even try a Minimus seven tweeter in there.
The passive dome thing is directly connected to the inside of the cabinet, but its super stiff, I'm thinking this must help the woofer get up to the relatively high crossover point (2500)
The cabinets are probably 5/8" MDF, but they are stuffed half full with fiberglass.
No crossover really, except for a single 3.3 uF cap on the tweeter, with the woofer running full range. Again like the minimus seven but there did not seem to be an inductor in here.
