Speaker relays? Don't want to appear too ignorant, but could you elaborate on why that is an issue? Those early Pass designs were pretty well received, especially the 545.
Just trying to learn a little more here.
Thanks.
cnh2
the 555 does not have a speaker relay and i don't imagine the botl 535 has one either. This alone makes them non-starters for me.
No protection system with output relays to open and disconnect your speakers if the output transistors go south. In such an event, your speakers would take the full DC power supply voltage.
Thanks, that makes sense. I have a further question though; certainly Adcom cannot be alone in such a design? Aren't there a lot of other mid-fi amps that also fit this description? Not that I'm advocating risking your speakers but I do know a lot of people who use GFA 545 and 555 amps and I have yet to hear one of them say that their Adcom has fried their speakers?
It would seem that this is not a very common occurrence, no/yes?
cnh2
Which one would you keep?
I have both but haven't listened to them yet.
I use an Adcom GFA 545, and I have never, every had any problems of that sort with it. The only time I had it repaired, was right after I bought it (used) and it was a faulty power switch. It has been an amazing amp (also had the 535). You cannot go wrong with the Adcom.
Besides, I would look at it from a standpoint of liability. Adcom is a decent, well known company. The negative advertising they would get through word-of-mouth if their amps would destroy speakers because of an internal failure would be extreme and very detrimental.
You could always add one of those Adcom speaker selectors that feature internal fusing. That would solve the this "problem" concretely.
