I thought I’d share my experience with adding central AC to my 90+ year-old home.
Here’s a recap of some information about my house:
- Built 1925
- Two story. Unfinished basement. Unfinished attic.
- Originally no ductwork. Home has boiler / hot water heat (radiators). Never had central AC. (I’ve been using window AC units in this house for 33 years.)
- Stucco exterior. Lots of windows.
- Plaster and lath walls. (No insulation in walls).
- Upstairs: 3 bedrooms, bath, hall. Total: 720 sq ft upstairs. 8 ft ceilings.
I installed the top-of-the-line Lennox Signature Series XC25 outdoor unit, and CBA38MV-018/024 air handler. 2 ton rating.
The CBA38MV-018/024 indoor air handle features multi-speed operation via an ECM (Electronically Commutated Motor), Lennox Quantum™ Coil, 10 kW heat strips (which I had installed for backup in case my boiler fails), and Merv 16 filter. Lennox claims: “The CBA38MV is the industry's most quiet and efficient air handler, providing reliable comfort, more consistent temperatures, and enhanced humidity control in all types of environments.”
The XC25 outdoor unit is described as a variable-capacity air conditioner. 26 SEER. Lennox claims: “The XC25 is the finest air conditioner Lennox makes, and one of the main components of the Ultimate Comfort System™. The most precise and efficient air conditioner you can buy.”
iComfort® S30 Ultra-Smart Thermostat.
The outdoor unit was installed on a pad on the ground behind the house. The air handler was installed in the attic (suspended via unistruts), with ductwork feeding rooms upstairs, plus one duct is installed through an upstairs closet to a vent in the downstairs dining room. (This is the only upstairs closet that is aligned above a living space downstairs, and therefore the only convenient location for a duct feeding the downstairs.) A large duct is at the top of the stairs, dumping cool air down the stairwell. A single return vent in the upstairs hallway. All wiring and pipes were routed from the attic through a laundry chute to the basement. The drain line goes to a floor drain in the basement. The refrigerant and power lines route across the basement, through the rim joist to the outside unit.
(An alternative that I investigated was installation of a ductless mini-split system with ceiling cassettes in each room upstairs. (I refused to consider the ductless mini-split wall-mounted units due to aesthetics.) All five contractors that I spoke with declined to propose such a solution, because large holes would have to be cut in the ceilings, and the holes would have to be framed-in for the cassette units. All contractors recommended the traditional air handler installation described above instead of a mini-split system, and therefore that’s what I contracted for.)
A top-of-the-line Panasonic bathroom exhaust fan was installed above the shower in the upstairs bathroom to help with humidity control. It is vented through the roof. (I don’t know why AC contractors refuse to do this work. My electrician installed the bathroom fan.)
After the AC system was installed, I had insulation added to the attic, including foam and seal of attic floor penetrations (e.g., wires, plumbing, HVAC boots), and insulation was sprayed onto the rim joist in the basement.
I had to upgrade my electrical service from 100 amp to 200 amp in order to install this new AC system (with heater strips).
When the outside temperature is below 92 degrees, the AC fan runs (automatically) at a low speed, and I cannot hear it run.
When the outside temperature is over 92, the fan runs (automatically) at high speed for most of the day, and I can hear it running. In response to my complaint about the noise, a technician adjusted the maximum fan speed down somewhat, which reduced the noise when the fan is running at its highest speed. Currently on hot days the AC system can be heard running at what I would describe as fairly loud - not obnoxiously loud – but not nearly as quiet as when the outside temp is below 92. I’m somewhat disappointed in this. (The highest temp we’ve had thus far this spring is 96.)
The system is able to maintain the indoor temp at 73 when the outside temp is 96. Given the fact that it must run on high for 10 – 12 hours when the temp is 96, I’m somewhat concerned if the system will be able to keep the house cool when the outside temp is over 100. Time will tell.
Because the system runs anytime it’s hot outside, and automatically adjusts the fan speed and compressor, the indoors is (thus far) always uniformly comfortable. No fluctuations in indoor temperature. No room-to-room temperature variation.
Downstairs I’ve retained a window-AC unit that is built into the wall in the breakfast room. Generally, I don’t need to run this downstairs widow unit. (I ran the downstairs window AC one day when the outside temp was 96 and I had 6 people in my living room.)
Overall the installers did a good job, except for two issues.
The installers had to cut holes in the plaster ceilings. One issue I didn’t anticipate, and therefore didn’t include in the Statement of Work, was sealing the ductwork boots where they come through the ceiling. After the installers left, I removed each register, and used backing rod (where needed), two applications of caulk, and 2” aluminum tape to seal the boots. If I had it to do over, I would have specified that the contractor complete this work. (My concern is about dirt from the attic (and unconditioned air) getting into my home.)
The installers initially used zip ties to suspend the flexible ducts in the attic. This pinched the flex ducts, and at my request the installers removed the zip ties and used wider straps.
I did not make this investment expecting a payback from energy savings. While it will be interesting to see if I have lower energy usage this summer vs. the last 2 years (using window AC units), there is no way that my total investment will be repaid based on energy savings during the lifetime of the system.
Thus far I’m satisfied. Compared with window AC units, my house is more uniformly comfortable, and quieter (particularly when the fan is running on low). If the system can handle 100+ degree heat, and it works reliably for a number of years, I’ll be happy with the investment. I invested considerable money and time (defining requirements and coordinating contractors) to make these upgrades to my home. Considering that we’re having record high temperatures before summer officially begins, I’m glad I made the investment.
