Ever since my thread of nearly three years ago now about resuscitating my Pitiful X-202 (seen here):
http://www.audiokarma.org/forums/index.php?threads/pitiful-x-202.551073/
I've had a number of requests for more specific information about how to implement one of the modifications I did to my unit, but only generally touched on in that thread. Specifically, it converts two of the rear panel barrier strip terminals in each channel into output tube test points, so that adjustment of the DC Bias and Balance controls can be done far more accurately, and simply too since the modification then means that the bottom panel no longer needs to be removed to facilitate these adjustments. Along with the usual installation of individual 10 Ohm cathode current sampling resistors, this modification also requires removal of the circuits facilitating the antiquated damping control feature of this unit, which then frees up the necessary rear panel terminals. While the installation of the individual cathode resistors is rather routine now for many who frequent this forum, removal of the damping circuits to allow re-purposing of the terminals is not.
I had intended on opening my own unit back up to take more specific pics to support the text of this thread, but then I was contacted by one of this forum's international followers regarding restoration of an X-202 that was going to be purchased here in the states. That led to a coordinated shipment of it directly to me for restoration before ultimate shipment to its new owner over seas. Since the test point modification is part of a suite of modifications being installed into the unit, it made for the perfect opportunity to show the execution of it in detail. So I'll kick it off first with a couple of pics of the unit that's being restored to set the stage. The pics that follow in succeeding posts will then detail the work involved. Since this is a client's piece, you will see other work in progress in some of the pics as well. I'm happy to discuss it, but the focus of the thread is primarily to address the test point modification. In addition to the basic restoration work then, the list of modifications being installed includes:
SAFETY MODIFICATIONS
1. Removal of damping circuits to facilitate rear panel test points.
2. Installation of individual 10 Ohm cathode current sampling resistors.
3. Installation of Screen Stability resistors.
4. Installation of CL-80 current limiter.
PERFORMANCE MODIFICATIONS
1. Removal of the permanent LF filter circuits included throughout the design.
2. Installation of EFB(tm) to maximize performance and output tube life, and reduce generation of heat.
PICS INCLUDE:
Below: Some guys have all the luck! Have you ever seen a more pristine unit? Note that on the later versions like this one that they finally got the filter switches correctly labeled as Low and High Filter switches -- this because they affect their respective frequencies on ALL inputs. On my earlier version unit, even though these switches function identically in the circuit as they do in later versions, they were labeled as Scratch and Rumble Filter switches -- leading you to think that they only operate on the phono settings, which is not true. Even with the earlier versions, these switches affect ALL inputs.
Below: It's also got one of the cleanest top sides as well. Stickers indicate tube testing results.
Below: The unit as built by Fisher -- bone stock.
Next time, we'll get started.
Dave
PICS INCLUDE:
Dave
