Hi AK! I’ve been lurking for a while, getting a lot of helpful information as I’m starting to get into higher quality (I hope) audio gear. So first off, thanks to all of you who share your knowledge here!
My first project is getting a pair of EPI 105s running again. As part of that, I removed the terminal plate (not sure if that’s the proper name) to rebuild the crossover with a new cap, larger gauge wires, and 5-way binding posts instead of spring clips.
Now I’m wondering how to glue to terminal board back into the cabinet. I tried Gotilla glue, but after letting it cure I used a flashlight to check for possible air leaks, and a lot of light was coming through. Does anybody have a suggestion for what to use?
One difficulty I can’t really put weights on the board because the crossover parts take up a lot of space, so I’d need something that sets up relatively quickly, even if the cure time is longer.
Any thoughts would be greatly appreciated.
