Briant8
Hi all,
So I sprung on those ADS midranges on the auction site here recently in order to replace a bad one on a set of L990’s.
Fortunately they came packed very well to protect them from outside evil forces.
UNfortunately on the inside, they came wrapped in an (impressive) amount of plastic bubble wrap.
Only
Directly on those magnificently sticky domes...
(Can you see where this story is going )
Sooo... anyways, yep. Plastic stuck tight!
After a few nights reading pretty much every ADS sticky driver cleaning thread I could find, I decided that heat and prayer were the way to go.
With a bit of gentle hairdryer heating and a toothpick, I was able to slowly pry the plastic from the domes.
The plastic came off cleanly, but what was left is what you see in the attached pics.
Clumpy glops of the doping goo on the dome.
Any thoughts?
Any ideas on how to smooth it out?
Should I even try?
Will it make a difference?
Thanks much for any wisdom,
Brian
